Design SuiteEditing curtain wall frames and panels
Tool
Tool set
Edit Wall
Building Shell
The Edit Wall tool's Edit Frames and Panels submodes manipulate the frames and panels of curtain walls. Once a curtain wall is selected with the tool, the modes allow you to select frames and panels; delete frames and panels; add, split, and combine frames; move frame and panel sets along a wall; and edit frame and panel settings.
Curtain wall grid patterns, including the location of frames and the attributes of frames and panels, are based on the grid definition in the Definition tab of the Wall Preferences dialog box or in the Curtain Wall Grid dialog box. Edits made to wall instances do not affect the grid definition. See Concept: Editing guidelines for curtain wall grids for a discussion of the interaction between the grid definition and any custom edits.
Mode
Description
Edit 3D Wall Peaks
Activates the modes to reshape curtain wall heights and add or delete vertices; see Reshaping walls
Activates the modes (described below) to reshape curtain wall frames and panels
Select Frame
Selects one or more frames
Select Panel
Selects one or more panels
Add Frame
Inserts new frames into the curtain wall
Split Frame
Splits a frame into multiple pieces, so that one portion of the frame can be independently moved, edited, or deleted
Combine Frames
Combines two collinear frames into a single frame
Move Grid
Moves an entire set of frames and panels relative to the curtain wall
Settings
Selected frame or panel parameters can be edited
Editing curtain wall panels
Adding new frames to a curtain wall
Splitting curtain wall frames
Combining curtain wall frames
Moving a curtain wall grid
Changing selected frame or panel settings
Curtain wall preferences
